- 8 Sep 2003
- Outside
Nearing the end of my house renovation and it's the downstairs cloakroom's turn. It was really poorly fitted (much like the kitchen) and we had been using it for storage mostly which was becoming annoying.
Ripping out...
The previous owner had boxed the pipework, cistern and boiler up with plastic cladding. Reasonable idea but hilariously poor finish - they also drilled in to the boiler cover to hang a cladded piece for a false ceiling - groan.
Once everything was out, I lifted the lino to see this...
It was plasterboard... on top of t&g chipboard. I assume they used the plasterboard to reduce the step down in to the bathroom but ... just wow. Anyway, the plasterboard acted like a sponge and rotted the floor. Joists ok.
Fast forward, noggins added to joists, visqueen down, 18mm ply + 6mm no more ply fitted for tiles and walls battened and boarded and plumbing ready for taps.
Added some 15mm white mfc to the sides of the walls and plan to overlap with 15mm mfc behind the back to wall toilet to provide a fitted unit + boxing in for the pipework.
Ceiling filled ready to be lined (skimped on the skim as it's a downstairs bathroom) and cabling jigged around ready for pull switch.
Still need to work out how to box above the boiler.
Work delayed a bit due to easter working but the next few days I need to line the ceiling, finish the boxing in at floor level and start tiling.
Ripping out...
