Was your 2008 3 series a manual?
Yes, the auto's don't have it as they don't need it.
[TW]Fox;26223072 said:Yes, the auto's don't have it as they don't need it.
[TW]Fox;26223129 said:Unless it's similar to the Auto-H functionality ZF8HP fitted BMW's have I'm not sure I understand what purpose hill-hold-assist serves in an automatic? The gearbox holds the car on the hill if its in drive?
[TW]Fox;26223129 said:It's generally a feature thats helpful on manual gearbox fitted cars as it holds the car for those few seconds between releasing the brake and pulling away with the clutch. An auto wont roll back when you release the footbrake?
[TW]Fox;26223129 said:Unless it's similar to the Auto-H functionality many ZF8HP fitted cars have (This puts the car in Park and applies the handbrake automatically if you stop, so a bit more than just hill hold assit) I'm not sure I understand what purpose hill-hold-assist serves in an automatic? The gearbox holds the car on the hill if its in drive?
Hill hold assist only holds onto the brake for a couple of seconds after you release it, so it's still possible to roll backwards if you want to.
[TW]Fox;26222966 said:This thread is a real insight, this is yet another trivial feature that's standard on pretty much everything else these days, my 2008 3 Series had it!
So, Audi claim that it isn't something they would usually fix
So, Audi claim that it isn't something they would usually fix and that the perspex cannot be changed on its own. However, "as a gesture of goodwill" they will contribute 50% of the cost of the part (the whole unit) and labour involved to replace it.
They are quoting the part at £640 and they will get back to me with regards to the labour involved.
This has now got me thinking... could this be an opportunity for me to change it to the colour DIS?
So it's going to cost you £320 to put right you new approved used Audi then, doesn't sound good to me. Sounds like they have already admitted it should be fixed by the offer of good will, they just need to pay for it all. They won't upgrade it to colour dis as it wasn't built with it.
If I was to pay the difference for the parts, would it be possible to do? I have been doing some Googling but cannot find the instrument cluster with a colour DIS. To be honest I don't even know if the colour DIS would work with the MMI Radio Plus I have.
