[TW]Fox;26227255 said:This is in every post you make, btw![]()
For those wondering why you have hill hold on an automatic, try stopping on a very steep hill - it can roll back!
That is correct dsg can and will role back on a steep hill.
Lol, you say 'that is correct' and then talk about a different type of gearbox.
Whatever happened to clutch control
I can't see me trusting a hill hold assist on a manual. Also sometimes I like to roll backwards without bothering with reverse gear.
I said what quoted is correct. And yes dsg can role back on some cars.
Do research before being a douche about it.![]()
Hold assist on the VW uses the last known brake pressure to hold the car, not the handbrake, the handbrake is only active if the car has been stopped for a few mins.
Works really well on the flat too, stops DSG creeping the car forwards, it's a total pain when parking though, which is why i wouldn't want to activate the system unless you had a button to quickly turn it off.
Might be worth asking this guy about colour DIS:
http://hazzydayz.com/a6-4g-s6-4g-rs6-4g-2012-82-c.asp
Iirc DSG didn't creep initially and was added in because people expected it in an automatic. I had a DSG without hill hold and found it a pain to make a smooth hill start.
I guess you have tried a car with it? There is little to dislike. Typically only hols for a few seconds anyway.
DSG isn't a torque converter type automatic with the typical creep function that is being referred to...
[TW]Fox;26234276 said:Exactly, DSG is an automated manual with clutches, so it didn't creep in the way an automatic does. It only does so now for the reasons you state IIRC.
How many keys did you all get with your A6 C7? I have two, but apparently there should be a third plastic emergency key which fits in the door lock and starts the car by pressing it on the dash? I checked the MMI and it does say that there are three keys associated with my car. I have emailed the Dealer who told me there are only two keys with the A6 c7, but I think that's rubbish...so has any one else got three keys?
I got 2 normal keys and one black plastic one which does what you mentioned. This is the third key your MMI states.
Well, that was easier than I expected.... Poole Audi just phoned full of apologies and said they will sort out the keys and recode my car if I take it down to them, they will email me to let me know when the keys arrive.![]()
Reading Audi may have claimed wear and tear![]()
Yeah...I have heard some horror stories about them tbh since reading this thread...I would email or phone Audi UK with your complaint if I were you, they might be able to help you. They are an approved dealer after all so ultimately have to answer to Audi themselves. I certainly wouldnt accept that damaged console.
