- 16 Apr 2010
Are there any specific brands which I should be looking at or avoid?
I should have added a 2GB will be fine.
looking at the prices of a new 780 my budget won't stretch that far and I'd only buy a used one from someone I trust so it looks like a 770.
Has to be Nvidia. My budget is a max of £275
Looks like a very nice card indeed. My issue is that I've seen some 780's go on eBay for around that money or even less and I'm just concerned that perhaps I'm not doing the right thing and should buy a used 780 but that takes me back to the problem of not knowing the source.
In B Grade there is a windforce ghz edition here > http://www.overclockers.co.uk/showproduct.php?prodid=BG-390-GI&groupid=595&catid=683
Its £329 but you get 90 days warranty with OCUK and sometimes whatever is left with the manufacturer, most of the time B Grade is just customer returns ( for whatever reason ).
if you can stretch to £329 then thats a lot faster out of the box and safer than the Bay.
EVGA & Gigabyte have the best RMA process right now so I would go for one of them but your not going to buy any decent 780 for much less than £400 so perhaps for £275 look at a decent GTX 770 instead.Are there any specific brands which I should be looking at or avoid?
