- 23 Dec 2009
- RG8 9
Builders are coming in next week and doing a lot of renovation work, including a complete bathroom refit.
My cold water pressure (mains fed) is very high (almost too high to be honest) so the builder has said that a pump would be good to regulate the flow of hot water (mavity fed) to both the bath mixer tap and and the shower they are fitting.
I want to buy a Stuart Turner Monsoon pump due to the fact that they are very highly rated and come with a good warranty (and are a local firm).
The question is, am I likely to need anything more than a 2 bar pump and would getting a 3 bar pump be overkill?
I need to order it asap so any advice would be helpful. Money is not a concern as I can get the 3 bar pump for a tenner more but am more worried about overkill on the hot water pressure.
