- 7 Aug 2012
TBF, you could easily remove the fan and stick on a couple of AP15's (if you have any/ or can get your hands on any) and probably take another few degrees off the temps anyway, even if overclocked slightly. Given the cooling solution on the 295, there is no need for the throttling speed to even be close to being approached.
