The Battlefield 4 Thread ~ Server details in opening post ~
Status
Not open for further replies.
Why not? The shot was on but the game decided it would be more fun to do what its best at, glitch. :(
TV guided missile are easy to evade a good strafe with hydra and 30mm is way more deadlier then a tv in a jet and besides it leaves you very vulnrable as you cant stear you
r jet
G3 + 8x scope + bipod was the best gun ever!
Yep, awesome gun, iirc i ran with an ACOG scope. M1 garand if you were a bf veteran was another corker, not ideal for up close engagements but awesome stopping power at range.
Very frustrating tonight trying to play tdm, this game gives such an advantage to low ping players. Every 1 on 1 situation where i fire first, im dead. Cant believe the difference in it when ive played it on a decent connection a few times.
The netcode issues favour high ping players for actual hitreg.
Are you sure it cant be attributed to hipfire vs ads (remember if you start hipfiring then switch to ads without pausing you still have the hipfire deviation values), dps and rps?
There was a video a while ago that proved that low ping players to a certain degree are not favored at all.
Even happens when i shoot at someone at point blank range. Indeed ive noticed the deviation when switching from hip to ads. Which brings another odd one, quite often when you do go to ads (not firing) the scope/red dot aim point shoots way off to the side of the target your intending to shoot. It's even more pronounced with telescopic sights of x8 and above.
If you fire from the hip and go ADS you default to max ads spread which is an improvement when they patched it from max hip spread. It's still not great, but better than it was
Are you talking about the bug where if you press fire, then ADS in quick succession then your spread is reflective of the hip fire not ADS? Think I saw this on jack frags 'did you know' series.
Yes and it got fixed or at least improved, it was intended.
Also guys bare in mind there is visual recoil in BF4, once you have fired your first bullet your "red dot" is no longer your aim point, your laser / centre of screen is. Visual recoil is an animation but doesn't reflect recoil at all. Blue tack crosshair FTW
Are you talking about the bug where if you press fire, then ADS in quick succession then your spread is reflective of the hip fire not ADS? Think I read this on jack frags 'did you know' series.
Theres another issue with swapping from hip fire to ADS to where if you get it right it incorrectly applies your current aim angles and ADS state to previous hip fired rounds (upto about 4 I think) if they are still in the rollback queue - its kind of weird but once you notice it happening you'll know what I mean. So you can shoot a few rounds off target then ADS and they will suddely be on target and have the ADS spread modifier applied. (At first I thought it was just incorrectly client side predicting the hit markers but it is actually applying damage).
EDIT: Oh and this is the kind of canted iron sight stuff I do find a bit satisfying https://www.youtube.com/watch?v=OZv9FjVZvUA (server was lagging a bit).
Popped onto the test range and equipped a laser sight in combo with a red dot scope. The below shots show something a bit odd.
In the above i fired a round at the target and used it as a ref point on which to point the laser beam. Not perfect though as even when standing still your weapon moves a little.
Red dot ads
When you go into ads mode, the centre of the scope doesnt match up with the red dots position, it tends to move up and to the side of it. No biggie at close range like above, but at distance this would be magnified quite a bit.
Its msi afterburner, ver 3.0.0 beta 19. In the settings menu under monitoring you can select whatever info you want displayed on screen. Does both gpu and cpu.
ok ive evga presicionx and cant get it to work on that one, cheers will try msi ab:D
Siege of Shanghai TDM/Domination - noobs can't get kills using skill so camp on the roof shooting down at people. Should have been aborted.
Status
