Have i fitted this correctly
8 Feb 2004
North West
New to this Corsair liquid cooling stuff,
Also, it came with 8 screws to mount the fans on the radiator, however no screws to actually mount the Radiator and fans on the case, so had to suffice with the 4 fan screws that came with my 750D! Not good.
Corsair SP fans should be used on a radiator really. also, it should come with 4 smaller screws unless its an oem version you bought?
That's irrelevant, he's made a poor decision, might as well have left the standard fans on - plenty of options for him to choose from.
AF140's will be absolutely fine...
They were probably bought for aesthetics.
The stock fans are really good if you setup the correct profile. Mine don't go over 900rpm using a custom curve setup in Corsair Link 2!
