- 5 Sep 2011
- Surrey
Yeh makes sense for multi rail PSU. You'll definitely run into trouble.
Sure I seen it said, because some PSU's have multiple rails and you dont want to be pulling all from a single rail so you need to check where the cables are connected on a multi rail PSU.
http://www.legionhardware.com/articles_pages/amd_radeon_r9_295x2,3.html
I think they are referring to molex adapters etc with that statement.
As some multi rail PSU's dont do 28A dedicated AMPS per rail,
This beast is "only" 25A per rail - http://www.overclockers.co.uk/showproduct.php?prodid=CA-298-SV&groupid=701&catid=123&subcat=2464
This one is 30A per rail - http://www.overclockers.co.uk/showproduct.php?prodid=CA-315-SV&groupid=701&catid=123&subcat=2464
I guess they are saying to ensure you are not daisy chaining of a single rail and making sure you use a separate cable across different rails from the PSU, a single rail PSU I guess doesn't matter so much.
Ya, pretty much that. No one in their right mind uses a multi rail PSU on behemoths like these anyway.
Not everyone checks whether a PSU is single or multi rail, they see a huge wattage and know its from a great brand such as the Silverstone and assume its going to be hunky dory.
So, I sell my EVGA 780SCs with titan standard coolers boxed on the MM and then pay the extra for this.
What extra outlay do I spend?
What % performance do I gain @1600p(4k soon)?
Will a 1200w coolermaster gold even run it? ( EDIT answered this myself 98A on 1 rail so yeah it's good to go)
Who said the reference 295x2 can only pull 375W? It has a TDP of 500W. Take a look at this thread itself- the PCI-E connectors can provide way more power than their theoretical limits.
I wonder if you have to use individual PCi-E cables and not daisy chained ones, that may pose a issue.
