Then whats causing huge spikes in CPU and low FPS drops, With "Low fps like gameplay?"
Should I reset my OC on my CPU?
What GPU?
Test it.it may or may not have fixed it.
Then i'm out of idea's, overclocked?
The CPU thread thing is normal. on a 4 thread CPU it should be '4 threads with 3 threads used' 25% of threads are in reserve for back ground services outside of the game, mine reads '6 with 4 in use'
Ugh, I dont really want to reset my OC. But do you think thats the problem?
How have you managed to use so much system ram? I'd that is the source of the problem.
I fixed that, Now sitting at 6GB, 2GB spare and still have problems. So its not that. Its just AMD's drivers, No shockers!
Do you have the iGPU of your 3570K enabled? This is all starting to smell a bit like an iGPU memory leak.
Integrated GPU on the CPU, think its called lucid or something like that on Ivy.
