Hey guys, quick question:
In the absence of "proper" Maxwell showing up this year, I'm falling back on my February plan for a 270X for Wildstar Online. I'm a fan of quiet computing (a slow fan - baddumtish!), but I've also noticed there's a couple of 4GB models floating around. Only they don't seem to come with the manufacturer's best cooling or overclock
Questions!
1) Other factors aside, what's the quietest 270X (not passively cooled)? I'm eyeing up a Sapphire Vapor-X, but sadly OCUK don't stock it.
2) Is the jump from 2GB to 4GB worth it on this GPU for 1920x1200? I will be using 3 monitors total, but only 1 will be used for gaming; the others will have browsers/desktop stuff on them.
3) There's a couple of 280-non-X cards skirting the £200 mark. Are any of these decently quiet? Obviously the performance is a kick up, but I won't bother if it comes with extra noise. I want "Is it turned on?" kind of quiet
4) More a point than a question; I fancy going micro ATX next build, so oversized/3 fan cards may be a bit of a problem. Two fans is the goal.
Gaming will be primarily Wildstar Online, and massively modded Skyrim, both of which are just a bit too much for my current 6870 GPU. Possibly some Minecraft with shader mods, which is WAY too much for it, oddly enough.
Thanks for your advice
Questions!
