After two installations of win 8.1 went kaput, I've gone back to 7. So much nicer to use.
Look at a few Linux distros since they run rings around ANY Windows for looks and general use.
Works the same for me. How is "nicer"
Not for gaming!
I wish there was better support for that kind of thing.![]()
but you can always dual boot like I do with Windows and Linux,best of both worlds
.As much as I like Linux, I expect I'd just end up sticking in Windows most of the time for the "convenience" of having all my games ready to go.
I want a clean break to Linux when I do move, no Windows install left.
,two of each.
No it's not "metro" it's the Windows 8 start screen, so yes it IS Windows 8.
...As was mentioned, the UI is superior.
Its the same UI underneath. well 95% the same.
No it has two UI's the Metro and Classic. Turn off metro (add back the classic start menu) and you're left with the classic UI. The classic UI is 95% the same as Windows XP/Vista 7 UI.
I've set it up like this for a number of non techie users from 8 to 80 and they didn't notice any difference.
PEBCAK ERRWHERE
