- 10 May 2012
- North London
The best air cooler I have used is the Phanteks , and that with the stock fans too
Very true, especially if you get a really bad example of ib/hw. Not even high end custom water cooling will tame them.With the current crop of cpus as they are any of the top end coolers are going to be similar, the cpu to ihs especially on intels is what hold back cooling performance
Have SA SB-E Extreme and a new SA IB-E too. Like them both but like the IB-E better.
Any input on SB-E SE I've read a few reviews and fans are quieter than the SB-E. What is noise like on IB-E, quiter than SB-E? Also what do the extreme versions provide? Thanks
Bottom line: If nothing but a dead-silent PC will do, the CR-95C IcePipe warrants a closer look, but you've got to be hell-bent on silence to consider a solution as outlandish as this.
Sorry, but the best CPU cooler is the Nofan CR-95. Totally silent and keeps the CPU in spec. You can't overclock, of course, but that's a small price to pay for blissful silence.
