- 30 Jun 2013
It's been nearly a year since i did my watercooling loop and i think its time for a change.
This initial loop that i have now, i used 1 and a half litres of XSPC EC6 Clear, i like clear coolant and this has had no problem at all.
Now this time round i dont want to pay £9 odd for 1Litre of coolant. Instead i want to use something cheaper and this is where im running into some problems.
Which coolant/water to use for a watercooling loop - Distilled or DeIonized?
Also, what other things do i need to add within the loop if using distilled or deionized water and not a premixed coolant like XSPC's EC6 - Killcoil or Biocide?
Will the silver killcoil react/corrode to anything in my loop at all? I have the following components:
EK-Supremacy Clear Nickel Plexi
XSPC Razer Titan Block w/ Backplate
Alphacool UT 360
Alphacool UT 240
Phobya Balancer 150 Silver/Nickel
Alphacool D5 Pump
XSPC D5 Top
XSPC Assorted Fittings
Thanks in advanced
Alphacool UT 360
Alphacool UT 240
Alphacool D5 Pump
XSPC D5 Top
Thanks in advanced
