I just had this working, but it seems to have stopped.
Am I missing something?
Disable ULPS > Restart.
That's not even on my version. I did it in the BIOS and that seemed to do the trick!
Not sure what you mean, bios?
If you're using a Hawaii card you should be using the latest beta of afterburner which is beta 19.
http://www.guru3d.com/files_details/msi_afterburner_beta_download,5.html
