Sorry if I sounded awful in my previous post.
Two non ref cards in CF with a gap between them work very well providing you have got good air flow.
Three cards though mean that at least two of them will be right next to each other on the motherboard and things can get quite toasty. All three cards will be dumping nearly 1000 watts of heat into your case when flat out.
Three reference cards work ok as they dump the heat out of the back of the case but for this ear plugs are recommended.![]()
nah dont worry, you sounded fine, i just over expanded on my thouht to something i had little experience in, you were right.
but i still stand on the value i see, that sli 780 or r9 290, provide enough comfort that the Ti wouldn't really change, and for a difference of 400€ i thought it was important to point that out.
if he is looking to beat some benchs records he probably wont, if he just wanna play in extremly well condition my suggestion provides the same for 30% cheaper cost.
and no 3 ways xD just a 4k monitor instead
