Hi all,
Have been researching online and looking at some wonderful builds on here using hard acrylic tubing. I fancy having a go at doing this on my system, but I have a query.
As far as I can gather - the tubing between components has to be cut to exact length, so I am puzzled as to how you can possibly fit it between two fixed components for example res and cpu block as neither are movable - so how do you have enough room to get the tube in too the fittings at both ends seeing as it does not bend? Obviously it can be done - so I am missing something here - please enlighten me as to how it is done please.
Need to know before I think about ordering parts etc, also which is the best system to go for - fittings and tubing wise?
Thanks in advance to all you knowleadgeable geeks out there.
Mark
Mark
