I'm really annoyed with the size increase. Every review praised the device for its reasonable display size - why change it? My only hope is that this time, screen size customisation is part of Moto maker, with you being able to choose 5.2" or 4.7" and everything else being the same. If it is $400 though, that's fantastic.
Don't believe the changes until it's properly announced.
, camera, and more competitive SoC. I wouldn't mind if the SoC was still dual core as opposed to quad core.Don't believe the changes until it's properly announced.
The rumours almost always turn out to be accurate.
May work in a super skinny body/chassis? Moto X size wise I thought is bang on. Don't want something tablet sized in my pocket at work which can be 1, uncomfortable and 2, at far more risk of breaking.
and Moto Maker in the UK may be tempting - not that we've heard anymore about that. A choice of screen sizes may be the way forward though I'll admit I've no idea how practical that would be.
I've not seen the pictures but it may make the phone bigger (longer) than it needs be as per the HTC One? Having had a One with front facing speakers in the past I'm not sure they are really worth the extra body room required to house them. But, each to their own as they say![]()
It's unlikely the bars are simply the speaker and mic. Well, the top bar could be the speaker, but I don't know of a single phone which needs an entire bar for a microphone opening. Pretty much every phone I can think of simply needs a little needle sized hole, or at the very most a couple of slits or something. There's also no speaker holes on the back, and there's no space for them on the top or bottom, so by deduction the bars are most likely both speakers. We'll find out of Tuesday though I guess.
Will that happen probably not, but eitherway as it stands the Moto X is pretty much perfect for me now, plus it be one of the first handset's after the Nexus line to get 4.4.3 aswell.
