- 26 Apr 2004
- Milton Keynes
Hi Guys,
Looking for recommendations here because the range is a bit mind boggling.
I've done a bit of parts scrounging, and filled the gaps, and managed to put together a relatively nice HTPC. The trick is that the old Antec Sonata II case it's in is just a little bit too big for the room it's in.
(42.5cm H x 46.3D x 20.6W)
Ideally, I'd like a case that'll take an M-ATX motherboard, an ATX PSU and ideally, the Gelid Tranquillo cooler (which I believe is 153mm high, so perhaps ~17cm wide to account for standoff), and be as small (with ok airflow) as possible.
Given our room aesthetics, white would also be a bonus.
The machine doesn't need much in the way of 5.25"/3.5" drive bays, as I'm running the OS off a USB stick, and it will only have a maximum of one DVD drive. Additionally the machine only uses one PCI-E card for graphics/HDMI capability.
