I have a Kona Lanai 2011 with the following transmission -
Shimano Tourney EZ Fire Integrated shifters / Shimano Altus front mech / Shimano Altus SGS rear mech / Suntour CW-XCC-T202 chainset, 42/32/22 tooth Chainrings / Shimano HG30 8-speed 11-32 tooth cassette / 24 gears
I use it for commuting and recently when under load (either up hill or setting off from lights) the chain has begun to slip on the cassette.
I average 60 miles a week on it, and have done for 2 years now so I assume it's just worn out. I think I've let the chain wear to far and so will need a new cassette as well.
I don't think it's worth spending a lot on this bike, but I do want to sort this out.
http://www.chainreactioncycles.com/shimano-alivio-hg51-8-speed-mtb-cassette/rp-prod67295
I think to fit this I'm going to need
http://www.chainreactioncycles.com/x-tools-cassette-lockring-tool/rp-prod10183
Chainwise I was thinking
http://www.chainreactioncycles.com/sram-pc850-8-speed-chain/rp-prod21295
I used to play with bikes a few years ago, and remember that SRAM chains have powerlinks which made it easier to fit / remove. I no longer have my chain link splitter though, I guess I'm going to need one to shorten the SRAM chain to suit my bike? I do remember having problems with SRAM chains when splitting non-powerlink links - or them being stiff when re-adding them.
Am I right in thinking that chain rings wear much slower, and I should be OK leaving them or should I just replace the lot? I have noticed that in the largest chain ring that the gears don't skip. I'd put that down to just the angles that the chain is put into whilst in that ring.
edit; worth replacing the jockey wheels as well? http://www.chainreactioncycles.com/shimano-jockey-wheels-mtb/rp-prod885
