Thanks NirK, legend! You've swayed me, DIY mixing, here I come!![]()
If you want to buy seperate
100ml of 74mg nic base for £16 http://www.goforsmoke.com/100ml-unfl...ine-9812-p.asp (vapers emporium is cheaper but out of stock)
500ml of PG for £6 http://www.ebay.co.uk/itm/CLASSIKOOL...item565262b3ef
500ml of VG for £4.60 same supplier http://www.ebay.co.uk/itm/CLEAR-FOOD...item27c9be1ef0
or get it from Boots
Also i get my 10, 30 & 50ml bottles from here http://www.creamsupplies.co.uk/resta.../cat_3391.html
Then buy some 1ml, 5ml, 10ml and 20ml syringes and blunt tips off Ebay and i use some babies bottles or old cough medicine bottles for steeping a mix.
Chefs vapour is good for flavourings does capella, tjuice, PA, Fart, Inewaera, DV etc... use code AAEC for 10% off.
T-juice's Affro-dizziak tastes like the old cough sweets, and red astaire tastes like cherry soothers, both very nice.
Otherwise look at recipes and just buy the flavourings needed and follow the recipe.
There is enough supplies to roughly mix 600ml of juice above, you will just need flavourings.
Edit.
Vapers emporium have 72mg AG nicotine base in stock (AG is just VG diluted by distilled water to make it less viscous)
http://vapersemporium.co.uk/index.php?id_product=37&controller=product&id_lang=2
