PC Build advice purely for FSX
11 May 2014
Hi
I would like to build a PC purely for MS Flight Simulator X and wondered if the below specs will provide good performance. I would like to fly with good and complex addons. My budget is £1000
Antec 300 Three Hundred Ultimate Gaming Case - Black
Stage 1 Intel: Overclock of CPU - 4.2GHz Overclock - Haswell K Edition Processors Only
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail
Akasa AK-CC4008HP01 Venom Voodoo CPU Cooler
Asus Z87-PLUS Intel Z87 (Socket 1150) DDR3 ATX Motherboard
TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLYD38G2133HC11ADC01)
Gigabyte GeForce GTX 770 WindForce 3x OC 2048MB GDDR5 PCI-Express Graphics Card (GV-N770OC-2GD)
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
Corsair Builder Series CX 600W V2 '80 Plus Bronze' Power Supply (CP-9020048-UK)
Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02733)
Asus USB-N10 Micro USB Network Adapter Wireless-N 150Mbps
System Build Fan - Noiseblocker BlackSilent Pro Fan PLPS - 120mm PWM [EXNO-001]
I would be really grateful if anyone can give me feedback on possible performance of FSX if I used the above? I'm not looking for 60fps, but as long as I can land at Heathrow with a good addon I.e. PMDG 737 etc, UK2000 Heathrow, REX etc at around 20FPS then I'm happy. I can't afford a super rig unfortunately.
Also should I keep with Windows 7 or go with 8.1?
Many thanks
Hi
Are you looking for a pre-built system ? Or can you build your own ?
A few things. The new Z97 motherboards are available for order (Pre-release) and they are due around 16th.
I would change the power supply for a superflower golden green. The Corsair CX range are pretty average.
The case is also a pretty old design now. There are better ones available that you could work into the budget.
I use Windows 7 myself, and have no intention of going anywhere near windows 8 :D Although others will swear by Windows 8.1. I wouldn't have thought there would be a huge difference in performance between the 2 operating systems
Hi
I'm looking for either pre-build or custom. The only requirement is that it runs FSX quite smoothly and a £1000 budget.
Any advice much appreciated
This pre-build is pretty good for the money.
YOUR BASKET
1 x "Titan Bayonet" Intel Core i5 4670K @ 3.8GHz Turbo AMD Radeon Gaming PC £249
1 x Standard Build Systems - Dispatched within 7 working days £0
1 x 24 MONTH WARRANTY - COLLECT & RETURN £0.01
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02733) £73.99
1 x Corsair Carbide 200R Compact ATX Case - Black (CC-9011023-WW) £47.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - OEM £233.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £67.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x HIS Radeon R9 280X iPower IceQ X2 TURBO 3072MB GDDR5 PCI-Express Graphics Card £249.95
1 x No Sound Card Upgrade £0
Total : £981.91 (includes shipping : £12.50).
You can ask customer services to swap the Ram for something faster, as the above comes with 1600MHz. I would suggest 2133/2400MHz
Hi
Is this any better? This is a self-build one. I've decided not to overclock it as I'm completely green on that.
Specification
Asus Z87-PRO Intel Z87 (Socket 1150) DDR3 ATX Motherboard
Corsair RM Series RM 750 '80+ Gold' 750W Power Supply (CP-9020055-UK)
Price £987.55
Thanks
Hi
Specification
Price £987.55
Thanks
Overclocking is pretty easy on modern boards. Usually a few clicks of the mouse is all it takes. There is also a separate part of the forum where you can ask resident OCUK Overclocking Guru 8Pack if you wanted to fine tune.
You want to be looking at the Z97 motherboards, as these are the replacement for Z87. The new boards will support the refresh cpu's and also Broadwell when it is released.
You can drop the psu down to 550W if you only plan on running a single graphics card.
Other than that your spec looks ok. I still think you can do better on the case, but that is personal preference.
Thanks, do you know when these refresh cpu's and Broadwell are released?
