Dual boot
4 Aug 2013
I'm just going to build myself a new PC last build about win98
Im getting a Samsung 250gb evo ssd just for so
Would I be able to install windows 7 & 8 on it for dual booting
Will there be enough space on it for both
And can somebody point me in the direction of how to do it
Please
Thanks Colin
4 Aug 2009
Canterbury
Yes you can dual boot W7/8 (whats the reason behind this?)
Samsung 250GB will have plenty of space. You should still have at least 150GB free after installing both OS's + updates
I would install W7 and then follow a guide similar to this
tnx
tnx
14 Dec 2012
I like to set my dual\multi boots by setting up each OS on seperate drives.
Install each OS then set your prefered OS as first boot then to boot into a different OS I press F8 (Asus) and manually select that drive.
Then once the PC is turned off and on my default OS boots up automaticly.
I have tested this on Win 7, Win 8 , MAC OS X and Linux, works like a charm.
Admitadly my Obsidian 800 D with it's four hot swap drives on the front of the case helps out.
OP
4 Aug 2013
Thanks for the replies that's helped me out a lot
I was thinking of buying win 7 oem
And trying win 8 on the 90 day trial to see how I got on
Thanks Colin
OP
4 Aug 2013
Where's the best place to find the best hacks for windows 8 to make it more like win7
I'm getting on a bit to learn something so different
Thanks Colin
tnx
tnx
14 Dec 2012
I can't say, I just leave it as is.
One thing I do is unpin ever app from the Start Menu and pin my own installed software.
Just actually messing about removing the default apps from the install.wim and testing a new install to see what happens. My first test worked really well.
6 Feb 2004
England
i wouldn't buy anything just yet. grab the trial of windows 8.1 and install that. see if you can live with it for 3 months. if you really hate it then buy windows 7 otherwise buy 8.1.
