Hi there
Great deals from MSI on NVIDIA graphics cards:-
MSI GeForce TITAN Black Edition 6144MB GDDR5 PCI-Express Graphics Card @ £739.99 inc VAT
GeForce ® GTX™ TITAN Black is a masterpiece in design and engineering. Evolved from the award-winning GTX TITAN, the Black edition lets you take on your most graphics-intensive games with 10 percent faster performance, while still retaining whisper-quiet acoustics and cool thermals.
This is the elite gaming GPU for gamers who demand the ultimate pure gaming experience-the perfect balance of sleek design, spectacular performance, and groundbreaking technologies. Power your most extreme games, and even 4K and multiple monitors at 25 x 16, with high-speed double precision and 6 GB of frame buffer memory.
Like the original TITAN, the new TITAN Black edition also includes high-speed double precision for the NVIDIA® CUDA® enthusiast
Specification:-
- GeForce TITAN Black Edition
- Core Base Clock: 941MHz
- Core Boost Clock: 980MHz
- Memory Clock: 7000MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£799.99] Inc. VAT
Only £739.99 inc VAT.
ORDER NOW
MSI GeForce GTX 780Ti Gaming Edition 3072MB GDDR5 PCI-Express Graphics Card @ £479.99 inc VAT
A graphics card is the single most important element for more FPS. As gamers, we understand that not just any graphics card "will do". That's why we bring you the best of the best. We don't want to bug you with noise and heat, but we DO want to give you more performance. With MSI GAMING series graphics cards you get just that.
Most MSI Gaming graphics cards come pre-overclocked out of the factory. This simply means you get more performance out of your card, without spending any time on checking for maximum clocks and stability. Pre-overclocked graphics cards simply give more performance and you don't have to worry about damaging your card, it is completely covered by our warranty!
MSI's Twin Frozr has been the industry defining graphics card cooler. The first Twin Frozr kicked of the dual-fan trend and today MSI stays true to its dual-fan dual-slot design where others have to resort to less effective means.
The other part that the Twin Frozr cooler uses is a large Aluminium fin grid array that provides a huge amount of surface area for cooling. Heat from the GPU is transferred to the fin grid array by virtue of heat pipes with MSI's special SuperPipe technology. SuperPipes transfer heat twice as fast as regular heat pipes enabling an MSI GAMING graphics card to stay cooler than the competition.
Futhermore, MSI provide all new Airflow Control technology on Twin Frozr. This new thermal tech. is leading airflow to heat pipe by spcial deflector on heatsink, so it can deflect more airflow to heat pipes directly. In addtion,This exclusive heatsink design is increasing the area of heatsink so that enhancing the efficiency of dissipation much more.
One of the deciding factors in performance is the quality of the components used. That is why MSI only uses MIL-STD-810G certified components for its Gaming cards because only these components have proven to be able to withstand the torturous circumstances of extreme gaming and overclocking.
One With their aluminum core design, Solid CAP's have been a staple in high-end design mainboard designs and provides lower Equivalent Series Resistance (ESR) as well as its over-10-year lifespan. A Hi-c CAP is a very small, but super-efficient capacitor. Besides ensuring enough spacing around a CPU socket to install large coolers, it also allows for 93% energy efficiency. Thanks to Hi-c CAP's MSI mainboards are the most energy efficient in the market. It’s a new generation, form-in-one choke, which doesn’t generate vibration noise under heavy loading & provide 37,5% higher current output comparing with traditional ring chock. It’s very important when GPU is overclocked or under high loading, since it requires even more amount of electricity which can be provided through this component.
Specification:-
- GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 1020MHz
- Core Boost Clock: 1085MHz
- Memory Size: 3072MB GDDR5
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£529.99] Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
MSI Geforce GTX 780 Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- Core Base Clock: 954 MHz
- Core Boost Clock: 1006 MHz
- Memory Clock: 6008 MHz
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£419.99] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
MSI GeForce GTX 780 Lightning 3072MB GDDR5 PCI-Express Graphics Card @ £399.95 inc VAT
MSI, world renowned graphics card and motherboard manufacturer, has officially announced the release of the GeForce GTX 780 LIGHTNING. This product uses the new exclusive Triple Force Architecture and is equipped with a Triple Level signals LED. The card, from the inside out, represents the next revolution thermal design. The combined power of the Twin BIOS and the card's Enhanced Power Design equip gamers and extreme overclockers with the best graphics card. This superior performance is accompanied by a 20-phase power design that can unlock the limitless potential of the graphics card. Also featuredis the patented GPU Reactor powered back plate design which filters power supply noise and improves overclocking stability. The MSI GeForce GTX 780 LIGHTNING is built using Military Class 4 components that have passed rigorous certification testing in laboratories. With such powerful components, this graphics card is guaranteed to have an impressive service life and excellent overclocking stability. Additionally, the popular 3x3 OC Kits allow for gamers to effectively monitor the status of the graphics card. MSI products are renowned for leading the industry due to the company's innovative R&D, excellent performance, streamlined thermal design, and quality components and software. The MSI GeForce GTX 780 LIGHTNING is once again the most powerful graphics card.
The latest generation of MSI's GeForce GTX 780 LIGHTNING uses Triple Force Architecture. Equipped with a Triple Level Signals LED function, TriFrozr Thermal Design with independent fan control system, and PureDigital PWM control. The Triple Level Signals LED features green, blue, and red lights that represent light, medium and heavy power loads on the device. This ensures that players have complete control over their games or the overclocking process. The innovative TriFrozr Thermal Design with independent fan control far exceeds any traditional or custom cooler's thermal performance and ensures better cooling of the GPU, memory and PWM modules. This iteration of MSI's exclusive design builds upon the PropellerBlade and the Dust Removal Technology of the previous model, alongside seven 8 mm SuperPipes for unrivaled thermal performance. In addition, the PureDigital PWM control technology provides a more stable and accurate voltage signal than traditional designs. The PWM's reaction time is shorter and helps enthusiasts more achieve a higher stability in the most stressful of environments.
Twin BIOS is composed of an original BIOS and overclocking BIOS. The original BIOS allows users to obtain better performancethrough out of the box overclocking, while the overclocking BIOS is specifically designed for extreme LN2 overclocking. By removing restrictions, the capabilities of the graphics card are dramatically increased, which allows users to unlock the card's full potential. The enhanced power supply provides more phases of power than standard models. The GPU has 16 phases, which more than doubles the capabilities of standard designs. The memory of the power supply even has a independent power source, which further supports a foundation for extreme overclocking. Not to mention that MSI's exclusive, patented GPU Reactor filters out extra noise for a stable overclocking experience.
MSI always emphasizes top quality and stability when pursuing the highest in product performance. When developing products, MSI makes satisfying market demands and expectations its primary purpose. The MSI GeForce GTX 780 LIGHTNING introduces the latest Military Class 4 components to the series. The components have gone through rigorous testing in a laboratory to satisfy the Military Standard 810G. Regardless if it is the advantages of the low-temperature, high performance DrMOS 4, the double-sided CopperMOS thermal design, the highly durable and stable tantalum Hi-C Cap cores, the polished surface of the New SFC for added cooling, or the corrosion proof Dark Solid CAP, each aspect of the LIGHTNING ensures the best possible stability.
Designed specifically for overclocking, the 3x3 OC Kits are a must-have for all enthusiasts. The kit allows users to adjust the voltage levels GPU, memory, and PLL through MSI's exclusive Afterburner utility while monitoring GPU, memory, and MOFSET temperatures. V-Check Points also capitalize upon the multi meter measuring of GPU, memory, and PLL voltage levels to give users direct calibration data-a function that guarantees success in the world of extreme overclocking.
Features:
- 16+3+1 (20) Phase Power
- Propeller Blade Technology
- 8 SuperPipes and dense aluminium fins to maximize thermal dissipation
- LN2 Mode
- Triple level signals show the real-time load with different colours
- TriFrozr Thermal Design - Three PWM fans with independent control on the most advanced thermal design.
- Pure digital PWM Control - Digital GPU / Memory / AUX voltages
- Twin BIOS
- Enhanced Power - 16 GPU phases and 3 memory Phases on a custom designed 10 layers PCB for amazing overclocking potential.
- GPU Reactor for improved OC ability providing 300% higher power capacity and reduces power noise (ripple)
- MIL-STD-810G standard certified to ensure the best stability and quality.
- Uses DrMOS 4, CopperMOS, Hi-c CAP, new SFC and Dark Solid CAP.
Specification:-
- Core Base Clock: 980 MHz
- Core Boost Clock: 1033 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- Warranty: 3yr
Was [£429.95] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
MSI Geforce GTX 770 Gaming Edition 2048MB GDDR5 PCI-Express Graphics Card @ £229.99 inc VAT
MSI's Gaming Edition GTX 770 looks absolutely stunning with the black and red styling. The cooling is the latest Twin FrozR design which is designed to not only reduce temperatures further but also noise levels as well. So you can enjoy the latest games such as Titanfall with smooth frame rates and in complete silence too.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Clock: 1059MHz (GK104)
- Core Boost Clock: 1111MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2118MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 2 x 8-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£249.95] Inc. VAT
Only £229.99 inc VAT.
ORDER NOW
MSI GeForce GTX 760 OC Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
GeForce® GTX 760 is the new weapon of choice for gamers—a powerful graphics card that gives you fast, smooth, quiet performance in all your favorite titles. It’s packed with next-gen technology innovations, engineering, and features that let you crank up the settings and resolutions in graphics-intensive games like Splinter Cell: Blacklist.
Take hyper-realistic gameplay to a whole new level with NVIDIA GPU Boost 2.0 for max clock speeds, PhysX® and TXAA™ for great graphics, and NVIDIA® SHIELD™ compatibility for incredible portable gaming. Plus, instantly access the latest game-ready drivers automatically—the day a game launches—and optimize settings with one click using GeForce Experience™. Even auto-record all your greatest gaming moments with NVIDIA ShadowPlay.
Specification:
- Core Clock: 1085MHz (GK104)
- Core Boost Clock: 1150MHz
- Memory: 4096MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Processing Cores: 1152
- Shader Clock: 2116MHz
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a 1x Displayport
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 1x 8-pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£239.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
MSI GeForce GTX 760 OC Gaming Edition 2048MB GDDR5 PCI-Express Graphics Card @ £169.99 inc VAT
Specification:
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Winner of CustomPC Premium Grade AWARD with 93% overall score!
- Warranty: 3 Years
Was [£179.99] Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
MSI GeForce GTX 750Ti Gaming OC 2048MB GDDR5 PCI-Express Graphics Card (N750Ti TF 2GD5/OC) @ £113.99 inc VAT
GTX 750 and GTX 750 Ti cards give you the gaming horsepower to take on today's most demanding titles in full 1080p HD. They deliver 25% more performance than previous-generation cards and up to twice the power efficiency thanks to the next-generation NVIDIA® Maxwell™ architecture. Plus, they come loaded with GeForce GTX gaming technologies like NVIDIA GameStream™, G-SYNC™, and GeForce Experience™
Specification:-
- Core Clock: 1085MHz (Maxwell)
- Core Boost Clock: 1163MHz
- Memory Clock: 5400MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 640
- Display Connectors: 1x Dual-Link DVI-I, 1x HDMI & 1x Analogue
- HDCP Capable
- DirectX 11.2 Support
- OpenGL 4.4 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Extremely Lower power consumption (Maximum consumption 60 watts at stock speed)
- NO external PCI-E Connectors required
- Dimensions: 250x128x37
- Warranty: 3 Years
Was [£119.99] Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
MSI GeForce GTX 750Ti OC 2048MB GDDR5 PCI-Express Graphics Card (N750Ti-2GD5/OC) @ £101.99 inc VAT
Specification:-
- Core Clock: 1059MHz (Maxwell)
- Core Boost Clock: 1137MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£109.99] Inc. VAT
Only £101.99 inc VAT.
ORDER NOW
MSI GeForce GTX 750 OC 1024MB GDDR5 PCI-Express Graphics Card (N750-1GD5/OC) @ £79.99 inc VAT
Specification:-
- Memory: 1024MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Processing Cores: 512
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£89.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
MSI GeForce N210 SILENT 1024MB GDDR3 "Low Profile" PCI-Express Graphics Card @ £17.99 inc VAT
Graphics processing has become an essential ingredient to the modern PC. Nowadays, we simply demand more from our PCs. If you want to enhance photos, edit videos, watch movies, play games, or if you simply desire a Premium Windows® 7 Experience, the NVIDIA® GeForce® 210 graphics card brings impressive graphics processing power to your PC at an incredible value.
- Core Clock: 589MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1000MHz (Effective)
- Memory Interface: 64-Bit
- Processing Cores: 16
- Shader Clock: 1178MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: VGA, Dual-Link DVI-I & HDMI
- HDCP Capable
- DirectX 10 Support
- OpenGL 3.1 Support
- CUDA Enabled
- Warranty: 3 Years
Was [£19.99] Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
Great deals from MSI and OcUK!!
Specification:-
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
ORDER NOW
Specification:-
- GeForce GTX 780Ti
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
ORDER NOW
Features:-
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
ORDER NOW
Features:
- LN2 Mode
- Twin BIOS
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- Warranty: 3yr
ORDER NOW
Features:-
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
Specification:
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
Specification:
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
- HDCP Capable
- CUDA Enabled
- Warranty: 3 Years
ORDER NOW
