Hi Guys
It gives me great pleasure to announce a result of in house testing, This card is perfect for anyone looking for a silent build.
Totally passive performance from an overclocked card using our favourite after market VGA cooler, the Alpenföhn Peter 2.
This card configuration has been tested in confined cases in a hot room and temperatures have not breached 65C.
Excellent result from a capable and affordable solution.
This of course is built to order in house here at OcUK.
OcUK Tech Labs - EVGA GeForce GTX 750 Ti FTW Passive Silent VGA Solution @ £179.99 inc VAT
Tested passive in a restrictive case, and reaching a maximum of 65C using the Alpenföhn Peter 2 - Universal High-End VGA Cooler. The OcUK Tech Labs - EVGA GeForce GTX 750 Ti FTW Passive Silent VGA Solution is the ultimate gaming card for users looking for absolute silence.
GX-242-EAGTX 750 and GTX 750 Ti cards give you the gaming horsepower to take on today's most demanding titles in full 1080p HD. They deliver 25% more performance than previous-generation cards and up to twice the power efficiency thanks to the next-generation NVIDIA Maxwell architecture. Plus they come loaded with GeForce GTX gaming technologies like NVIDIA Gamestream, G-SYNC and GeForce Experience.
Specification:-
- Pre installed Alpenföhn Peter 2 - Universal High-End VGA Cooler
- Core Clock: 1189MHz (Maxwell)
- Core Boost Clock: 1268MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5400MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 640
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 1x Dual-Link DVI-I, 1x HDMI & 1x Analogue
- HDCP Capable
- DirectX 11.2 Support
- OpenGL 4.4 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Extremely Lower power consumption (Maximum consumption 120 watts at stock speed)
- 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Only £179.99 inc VAT.
ORDER NOW
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
