E90 Coupe, talk to me?
27 Sep 2004
Am I right in thinking Fox did a good write up on the E90 335i? Had a quick search but couldn't find it, only a comparison between that and a Lexus?
Looking to change my A3, I love the car, the build, the gearbox(DSG) but after last years oil pump issues, I'm still spending more money than I'd like to on it with not a lot of confidence.
I fancy a quiet cruiser with a nice bit of poke, RWD and solidly built interior; Specifically looking at the 325i but not sure what else to look out for. The S-line setup on the A3 is great fun but a bit harsh when it comes to long motorway journey. That and the 2.0T is a bit loud for a petrol engine.
What's the views on the E90 325i?
Cheers
A 325i would be very near the bottom of the list for me. Not fast enough being the number one downer on it's list. But fear not, the 330i would only be just above it.
335i though, that is near the top. Although I can't imagine it being a quiet cruiser. I didn't find the interior of my e91 inspiring at all either. Pretty bland. But felt solid enough. And should have the nice bit of poke you're looking for.
Having said that, my definition of a nice bit of poke seems to be way ahead of most others peoples though. I mean, I wouldn't have a 330i because it would be too slow for the fuel consumption, in my book. Just like I wouldn't have an R32 for the same reasoning. If it's a petrol with less than 300 BHP (or an easy to get to 300 BHP), it generally doesn't interest me. Obviously diesels are a different story with regards to power, but they generally have a bit of fuel economy to go with them (except for Audis).
Basically, what I'm saying is I wouldn't go for less than a 335i if I were buying another 3 series. But if you're wanting a comfortable cruiser, with a bit of poke, there are much better cars out there for that purpose. The M-Sport suspension, especially coupled with the RFT's aren't gonna give any extra comfort over and above your current S-Line set-up.
You'd need a 330i or a 335i else it'll feel slower. An E9x will ride a bit better than the A3 S line. However, it being a 'quiet cruiser' is subjective. You might find it a quiet cruiser from an A3, I'd find it like a sports car from a 5 Series, just how someone from an S-Class would find the 5 like a go-kart. When you say 'quiet cruiser' what would you say is similar?
Cheers xs2man; the reason I didn't consider the 335i is because of the running cost horror stories I've read, turbos failing etc.
You're both right, the 330 is looking like a good option in terms of performance. I want an 'upgrade' from the A3 in that respect not to end up with something a bit sluggish in comparison.
In terms of ride, I want a sporty car, that's why I'm drawn to the E92; I'm not expecting 5 series ride quality but for the car to be a bit quieter/smoother on the motorway than the S-line...which I highly doubt would be hard.
Looking at AT/Pistonheads the earlier models don't seem to have iDrive?
This would depend on the age of car you are looking at. Anything 6 cylinder petrol built after September 2007 that isnt a 335i is going to have an N53 engine in it which frankly is just as 'complex' and reliability-prone as the 335i is, so in that respect you don't really gain anything by not having a 335i.
The earlier ones are N52's, a reliable indirect injection engine. But then you get crap iDrive.
Doubt it will be, mine had a bone-jarringly ridiculous ride and the cabin was hardly quiet.
You only get iDrive if you specify Navigation. No Nav = No iDrive.
Everything said above really. You might think that S-Line suspension is so hard, nothing could even come close, but BMW do make a good go of it. The LCI is much better than the pre-LCI though.
You really need to test drive these cars to get a real feel for them. No point in assuming, and building up your hopes. Get yourself on AT, find a local M-Sport, preferably from a small dealer, and blag a test drive. Then you'll see where you are.
I'm not suggesting you don't make the move to a BMW. I was a big Audi fan, until I drove my first BMW. But you do need to make sure your eyes are open when you go in.
For example, lets take a quick look at fuel economy, according to fuelly, the average fuel consumption for a 2006 330i is 28 mpg (tracked over 600,000 miles), a 2008 comes in at 28.9 over 52,000 miles.
Compare this to a 335i and there you have 25 - 27 mpg, tracked over 1,000,000 miles. So fuel consumption is within 3 mpg. For the extra poke out of a 335i over a 330i, that's a bargain.
Now, if you can get an example with less than 60k on it, BMW warranty is a bargain (in my eyes). I'd personally max the excess and reduce the cost as much as possible. It's only really the big things you're worried about, and if / when they are done, you can cancel knowing it has been done properly if you wish.
Personally, I wouldn't take the performance hit for a less than £300 a year warranty. Not when fuel costs are almost negligible. But then, I wouldn't have a petrol over a 330d/335d unless it was the 335i. As in the 335i is the ONLY petrol e9x I would even consider.
I would take a 330i over a 330d every day of the week. It's smoother, more refined and simply a better pairing with that type of car.
Fair enough. If you're doing really low miles.
I'm always lured by the extra 12-14 mpg, and lazy way the diesel drives. Couldn't justify the extra £1400 a year in fuel to have the car below the car I'd wanted.
[TW]Fox;26319685 said:
Extra 14mpg? More like 8ish.
Head. Clouds.
It is pretty clear from Fuelly what actual, real world, consumption is like on the 330i and 330d. 26 - 28 mpg on the petrol, and around 40 mpg on the diesel. So unless mathematics has changed drastically of late, that would be a 12-14 mpg difference.
If 32 mpg was possible, as an overall average of all driving types, on the 330i, then I would probably be inclined to agree. Rather than an "on a run" figure. If I actually prefered the way a 6 cylinder petrol drove. 8 mpg isn't a HUGE difference, so if it's the driving style you prefer, then fair play. But it's not the 8 mpg, in the real world, and that's where it counts.
But none of that matters, as he (the OP) isn't looking for a diesel, he is looking for a petrol (presumably). And as I've already said, IMO the ONLY e9x worth looking at with that requirement is the 335i. Otherwise there are better cars out there for the money.
I wished my e92 330i was a 335i after a short while of owning it.
When you have the rock hard ride, terrible reliabilty, alloys made of cheese, not usually over 30mpg, it seems silly to not have some extra performance.
When it was working and I wanted to drive hard, it was great, but otherwise it was far from perfect :(
Head. Clouds.
Nice selection bias there, Fuelly isn't as useful as you think for direct comparisons between engines because generally the 330d and 330i are bought for slightly different purposes, I'd wager there are more higher mileage drivers in the 330d group than the 330i group which is going to skew the average upwards.
I have experience of both the M57 and N57 3 litre diesels. The M57 was in an E39 which was in the family for a good 5 years, alongside it I ran my 530i. It was as near as makes no difference 7-8mpg more efficient than the 530i in any given circumstance. On a run, 8mpg better. Around town? 8mpg better.
Now I've got a 530d - an F10 with the current N57 engine. Guess what, looks like it's about... 25% more efficient than the 530i is. Which is.. about 8mpg on a run :D
26mpg from a 330i? From my pre LCI early 335i with the less efficient N54 engine my average over many thousands of miles, 90% of which were me driving enthusiastically on A roads, was 28mpg.
Driving a much more efficient engine, with less power at a normal pace on less fun roads should easily see mid 30s average.
Not to mention the 330d is much better than efficiency wise than a 335d engine. The average figures people say they get is around 35-37mpg on a 335d and 28-30mpg on a 335i, hence Fox's 8mpg margin is between the models is about right. Whether or not you choose to believe it is another issue entirely.
Agree with above. Im a bit of a lamer, so i averaged just over 30 in my 335i over its 15k or so. Its a remarkably efficient engine for its power.
I remember doing a brim test here ages ago and got about 40 on a mixed/motorway run.
Edit: I averaged 37mpgz in my 530d a year or so before that in the same driving
Well, my first point was comparing results from fuelly, as that can be corroborated. However, it is also true that I have actually owned all the engines we are talking about here, except the 335i, for which I have stated that fuel economy on that engine is almost irrelevant, as it was worth it. Anyway, again, from fuelly, over 1,000,000 tracked miles on a 335i puts it 26-28, which is a good 10 - 12 mpg less than the equivalent 335d, not that this is what was being compared.
When I had my 330i, I was in the region of 26-28 mpg averaged over around 10k (I think it was actually 27.3 IIRC, but still well within the range I mentioned). And I didn't find it fast enough for that fuel economy.
My 335d averaged 37.9 over 17k which is about what you are saying. Although we weren't really comparing the 335d here. But was easily fast enough for that fuel economy, as it was much faster than the 330i.
I haven't actually owned a 330d for any length of time, I do know a few people who have, and they are averaging around 40 mpg, maybe a little more, which tallies up well with my experience of the 530d, which is currently kicking around 39.1 but is only on 8k, so still breaking in, and my last 6 tanks have all been within around 0.5 of 40 mpg.
So based on my actual experience, I will choose not to believe that the difference is only around 8 mpg. On COMPARABLE 3.0L non turbo petrol / single turbo diesels (i.e. second from top for each fuel type, excluding M cars).
As for the selection bias Fox, I was picking the years that had the most cars available, at around the age I thought the OP's budget would allow. I.E. 2006 - 2008 (not that he actually mentioned a budget, but the whole pre-LCI comment and lack of i-drive would suggest he is looking at around that age of vehicle). So it wasn't for nothing. It was to compare real world figures, tracked over 1.5 million miles. Sure, they are different cars, and may well be bought for different purposes, but surely this will even out somewhat over such massive miles covered? Not everyone buys a petrol bmw for drifitng roundabouts, likewise not everybody buys a 330d for uber economy.
And surely there must be a reasonable difference in economy between e39 diesel engines and e90 diesel engines? With the later engines being a little more economical?
And at no point was I comparing "on a run" figures. I could see 50 mpg "on a run" in both my 335d and my 530d, if I wanted to. Just as I could see 35+ mpg in my 330i. But neither is representative of actual running costs. Who is always driving "on a run"?
I don't know where you are getting your figures from. Fuelly seems to indicate that for recent years a 335d will return around 37mpg vs a 335i at 29mpg. For 2007 we are looking at 36mpg vs 27mpg.
For the 330i vs 330d for 2006 the figures are 28mpg vs 37mpg on Fuelly and there aren't any 330is after 2010 to compare with for some reason.
Looks like 8-9mpg to me :confused:
