Not being funny but Chrome uses WebKit, no? Same as Safari. And Chrome works fine on Windows.My 13" Retina MBP will happily let me browse the web in Safari for 9 hours on the battery. I don't use Chrome on the Mac because it's a badly coded piece of junk, fortunately the OS publicly shames applications that are eating up resources to hopefully convince the developers to do a better job. The reason you're having issues with Chrome is because it's Chrome, not because developers aren't allowed to make apps that can efficiently use the hardware they are running on.
Yup. On that note, why doesn't OSX support the ability to timeout and kill apps which are holding up a shutdown or restart? So annoying.Google's ability to write software in general is reasonably bad - Google Drive on Windows has a bug in it that leaves a 40MB folder in Temp every time someone logs in if they didn't shut Google Drive down before logging off (who does this?), and then it sits there preventing the machine from shutting down until Windows forcefully kills it before it can delete the garbage it created at login.
Faulty hardware? Realllyy? Come on dude... This is a brand new machine. I spec'd it out to 16GB and 500GB SSD. It came direct from the China factory since it was a custom build. It's not been sat on a shop shelf for months. If it was bad RAM or something then I'd be seeing far more crashes and segfaults as well.A lot of your issues sound like you have faulty hardware or are just personal preference issues. Resizing windows works exactly the same in Mac OS as it does in Windows - drag from any corner or edge.
I think the issue with window resizing is that the windows don't seem to have any visible edging chrome, which means there is literally a pixel or two of which you mouse cursor must be precisely over before it offers the resize cursor. It's not a major issue no, but you would have thought Apple, the masters of UX, would have sorted these fundamentals out by now?
Fair enough.I don't really do enough in Finder to run into any of the limitations that other people seem to have with it. If I need to move large volumes of data around I will use rsync.
Maybe. Response has been pretty good though. I thought I was going nuts but seems not as a couple people have said they've experienced similar issues.I think you'd have had a better response by posing your questions as questions though, rather than dropping a "OS X isn't as good as Windows" thread into the Apple forum.
You've misunderstood. I have a PC keyboard hooked up by USB, and I've set it to use the British PC layout and yes 90% of the keys work as expected but the ones I highlighted do not. There is no possible explanation for this other than: bug.The keyboard layout being different to Windows is exactly that, a difference. It's not broken. You can connect a Windows keyboard if you want and use that, just pick the "British - PC" layout.
I can't seem to get this to work? The two finger drag from right?The OS X equivalent of the notification area is the notification area that can be invoked by two finger dragging in from the right of the trackpad. This is far superior to anything that Windows has. The icons next to the clock can often be removed by holding down Cmd and dragging the icon out of the menu bar. If they can't be dragged out and there is no option in the application that put them there to disable the icon then feed that back to the developer.
The area I'm talking about is left of the clock, next to all the WiFi and Volume stuff. It's currently full of Dropbox, Chrome, VMware, Skype, Time Machine and Bluetooth icons. I only use one of them; see the problem here?
I'm not saying you aren't. I like my machine but if I could resolve some of these issues I would like it more.I am a lot more productive in OS X than I am on Windows, hence why I buy Macs.
This evening I had a new problem. My keyboard and touchpad stopped responding to all input. Had to hard-poweroff in the end. Not good. Seems it is a known issue but one which was supposedly fixed with a EFI update. Well, I assume I've got that update since it's not showing up as available to me on the App Store Updates. So looks like another OS bug for the list. FWIW I had just plugged in my phone to charge it via USB...
