Disagree. It's better then most. Also you shouldn't IMHO spread tim. One grain size in middle, then run prime for 30mins to let heat spread.
I've never heard this one before? Anyone else do this? How does it compare to spreading it?
May try the Gelid Solutions GC-Extreme. It seems to come out quite well in the OcUK test.
Marketing, people see MX-4 and immediately think it's better than MX-3 and MX-2 just because of the higher number. In reality, the MX-3 is actually better and the MX-4 was meant to be cheaper with similar performance. Unfortunately it wasn't as good but because people know the reputation of Arctic's thermal paste and this is their latest iteration, they immediately think it's better.
Thermalright ChillFacter II/III is better and cheaper. Prolimatech's thermal paste is also very good.
I also don't rate Gelid GC-Extreme that highly and I don't understand why people are suddenly recommending it. It came out a long time ago and was very good at the time, only for the MX-3 to come out and outdo it. Given there are even better alternatives these days as above, the GC-Extreme lags behind.
you been living under a rock?
Yes l would agree MX3 is slighly better but a pig to spread, where as MX-4 easy 2 spread and gives good temps.
True but as mentioned above, you don't need to spread it yourself, let the cooler spread the paste.
This is the best solution in my eyes for IHS or GPU. Really great ambient and sub zero. For delid Liquid metal is the one.
How do you recommend applying this stuff to a 6 core 4930K? Should I just spread the stuff like I’ve been doing for years or the pea sized blob?
I also use MX4 for core only GPU blocks and binning its not a bad paste.
Have you found the air bubbles that form when you spread the paste to negatively impact the temperatures? I personally also prefer spreading but a lot of people thing it is inferior.You can for sure yes but I am paranoid about coverage.
So I heat the IHS with a hairdryer so when you apply the paste it spreads very easy. Then I use a spreader to get as thin a possible coating across the IHS. Then apply heat sink as usual.
