I've found a lump in my front tyre
Given the large chunk of alloy is missing in the same place as the damaged lump, I guess you hit a kerb pretty hard.
Owie.
OK, cheers, guess it needs replacing!
Yeah the wheel is kerbed a bit, I live on a narrow street with some nasty kerbs :( There aren't any dents though.
pfft any tyre place worth their salt should be able to repair that,
they don't like to so will tell you it cant be fixed so they can con you out a new tyre.
tell them you know all about the reverse vacuum repairs they do and they'll see you right
