Project Clean and Tidy
21 Aug 2012
Hi guys, not so much of a build log but sort of, i got tired of looking at my old case so i purchased another which i have had my eye on for a while, here are some pics, any suggestions to anything simple i can do are more than welcome.
before:
After:
thanks for looking.
did u braid the ocz cables ?
i wanted to however i couldnt, as for some reason right before the connectors, i.e sata or pci-e OCZ put some metal anti twist thing made of metal and impossible to remove without damaging the cable and voiding warranty. no way to get the braid on so i just bought some bitfenix cables, much less hassle.
Not too sure. Holding out for the maxwell gpu's and to be honest at the moment there's nothing this thing doesn't handle without breaking a sweat. The mrs wants her yearly holiday first. Haha
How are the temps with the sli set up? really like this case just holding off firing till i know what temps will be with sli as im looking to sli at some point im running a h100i in pull in a cm690ii
Cpu at load doesn't go over 55. That's at 4.4ghz. Used arctic 5 paste
Sli temps. 90% of my games see the hottest card doing 70degrees dead on. Only titan fall has pushed the hottest card to 75. Mind you that's using a silent fan profile. With the fan profile set to 1:1 they average at around 65-70 degrees on demanding games. The weather has been nice today and the ambient temps wernt helping much.
Thanks for putting my mind at ease! im going to install the h100i in the cm 690 for the time being was getting 65 under load using a h80 and 33-37 idle although the case is in a 1.5 m x 3 m laundry room with a radiator next to it!
The joys of having to decorate your house before you can move in!
I'll definately be ordering the h4440 and will be water cooling the cpu and cards so should be a little bit cooler as well!
really prefer the black and red h440 to the other one. are you planning on fully watercooling your setup?
looking good anyway
looking good anyway
Eventually yes. However I'm holding out for what nvidia brings to the table next year as my gpu still handle everything maxxed out at 1080p. Couldn't rationalise spending so much for waterblocks for the 670's with the thought I may upgrade next year
yeah that's a good shout!
