I've recently bought a 2nd hand 7950. Performance in benchmarks at stock is well over double the 4870 1GB I had before, but of course I wanted to see how it would clock. More is...well, more
I've been using it at stock because that's plenty, but I did some benchmarking with various overclocks just to see.
It's 930/1275 stock, but went easily to 1000/1500 +20% power. GPU was 75C under constant 100% load. No worries - they're specced for 85C. I tried some different GPU and memory clocks to see what effect it had. Then I switched to a different hardware monitoring program and saw the VRM temps. 97C with the GPU at 950 and memory at 1500 (and GPU at 71C) with +20% power limit.
That seems far too high to me. I wasn't expecting them to be so much hotter than the GPU.
So I benched again at stock and the VRM temps were still 77C (GPU was 64C).
I'm using HWINFO64. Are the VRM temps accurate? What's normal for VRM temp on a 7950? Surely not 97C. Is it normal for them to run so much hotter than the GPU? I'm thinking that maybe the cooler on my card doesn't do much to cool the VRM (it's a VTX3D X-Edition).
I'm content running it at stock and will continue to do so, but 1000/1500 +20% power gives me a 45% increase in performance in Heaven, compared with stock, and it's only the VRM temps that are stopping me running it at that speed.
I've been using it at stock because that's plenty, but I did some benchmarking with various overclocks just to see.It's 930/1275 stock, but went easily to 1000/1500 +20% power. GPU was 75C under constant 100% load. No worries - they're specced for 85C. I tried some different GPU and memory clocks to see what effect it had. Then I switched to a different hardware monitoring program and saw the VRM temps. 97C with the GPU at 950 and memory at 1500 (and GPU at 71C) with +20% power limit.
