I was confident that this guy would turn up with a more definitive answer than mine
(Though he said what I said)
So is it because the 14.4's are the Mantle drivers that they are unstable with 3DMark ?
Benching - 13.12 WHQL
Gaming - 14.4 WHQL
I use 13.12 for both, whats better with 14.4 other than mantle? Who cares about mantle anyways, most people dont even play BF4 or Thief.
Apart from Mantle are there no game improvements from 13.12 - 14.4 ?
SourceSupport for the AMD Radeon R9 295X
CrossFire fixes enhancements:
Crysis 3 – frame pacing improvements
Far Cry 3 – 3 and 4 GPU performance improvements at high quality settings, high resolution settings
Anno 2070 – Improved CrossFire scaling up to 34%
Titanfall – Resolved in game flickering with CrossFire enabled
Metro Last Light – Improved Crossfire scaling up to 10%
Eyefinity 3x1 (with three 4K panels) no longer cuts off portions of the application
Stuttering has been improved in certain applications when selecting mid-Eyefinity resolutions with V-sync Enabled
Full support for OpenGL 4.4
OpenGL 4.4 supports the following extensions:
ARB_buffer_storage
ARB_enhanced_layouts
ARB_query_buffer_object
ARB_clear_texture
ARB_texture_mirror_clamp_to_edge
ARB_texture_stencil8
ARB_vertex_type_10f_11f_11f_rev
ARB_multi_bind
ARB_bindless_texture
ARB_spare_texture
ARB_seamless_cubemap_per_texture
ARB_indirect_parameters
ARB_shader_group_vote
Mantle beta driver improvements:
BattleField 4: Performance slowdown is no longer seen when performing a task switch/Alt-tab
BattleField 4: Fuzzy images when playing in rotated SLS resolution with an A10 Kaveri system
Highlights of AMD Catalyst™ 14.4 Windows Driver
Source
http://support.amd.com/en-us/kb-articles/Pages/AMDCatalyst14-4WINReleaseNotes.aspx
Matt's got it under control lol
Not all of us play Firestrike 24/7.![]()
Firestrike is definitely one of the best and polished games out there![]()
I bet that's not the only thing that gets 'polished' when you beat your previous best score.![]()
