GPU for Watchdogs @ 2560x1440p?
Just out of curiosity are you using HDMI connection?
Reason i ask is from what you explained is something i experienced in the past when connected via HDMI a few times. Went to DVI and not had the problem ever since.
Just thought it might give you something else to think about :)
I've checked all power cables and I am using a Display Port cable.
i also recently bought a 780 ti (gigabyte oc) and am having the problems u talk about. i have installed the latest nvida beta drive which seemed to greatly reduce (if not fix) the problem entirely, im yet to test more but since i installed it i only had the problem once for a split second. try this and see if it works :) i think its an nvidia driver problem and iv read else ware that rolling back to 314.22 was a solution too.
I currently have 337.81 installed as there are some major performance issues with Wolfenstein The New Order and this beta is supposed to address some of them; plus it includes optimisations for Watchdogs. I may revert back if it gets worse but i'd rather wait for a newer driver.
