- 26 Dec 2009
- North
(Note 3) For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16_1 slot; if you are installing two PCI Express graphics cards, it is recommended that you install them in the PCIEX16_1 and PCIEX16_2 slots.
(Note 4) The PCIEX8 slot shares bandwidth with the PCIEX16_2 slot. When PCIEX8 is populated with a PCI Express expansion card, the PCIEX16_2 slot will operate at up to x8 mode.
Support for 2-Way/3-Way AMD CrossFireX™ and NVIDIA SLI™ technology
I'm having the same problem , my 2nd 270x 4gb is coming tomorrow and I'm wondering which slot to use the 2nd or 3rd.. My mobo is X58A-UD3R ... Any idea doomedspeed ?
Surely the second PCI-E lane is blocked by your other card, no?
Third one down would be ideal.
