I've done a 200MHz bclk![]()
Was that 1.67 wound up or 2.5 wound down? You should have documented it, records to be had with regards to chipset base clocks
How did you get on with the pi's?
I wonder how far it would let you push a locked cpu's bclk??
how many front panel usb3 do you need?
ive seen few issues with via usb3 so could be why they dropped them?
key words here:
Was wondering the same, current rumours point to devils canyon delay. So might just push the button on a Gene and 4670k.
