- 29 Jun 2004
Thanks guys. I'll let you know how I get on
To access it from the internet, you can either forward the port 3389 on your router to the ip address of the machine. A VPN would probably be the safer solution though
ort Number format e.g. 192.168.3.3:33332What version of Windows will it have?
If it's it's a Pro or above version, then it will have remote desktop built in.
Free and simple.
Once you enable Remote Desktop on the new machine (let's call it the host), on any other laptop/pc on the same network, you just open a run box (Winkey + R) type in mstsc hit enter.
Now type in the computername of the host, enter the Windows username/password for that machine and you'll be connected.
No idea why people would suggest teamviewer or even mention forwarding ports lol
Because they're talking about over the internet, not on the LAN.
But the OP specifically asked about accessing devices in a LAN and not over the internet.
More secure would be to open another port on the router and forward that to 3389 on the local PC. You can specify the port when using MSTSC using the IP Addressort Number format e.g. 192.168.3.3:33332
