Male Grooming Dilemma
1. It doesnt grow back thicker.
2. Veet it, might get a rash at first if you leave it on too long. But it will disappear fast.
3. Or do the thing proper men have done for the last undreds of years and leave it as is.
As has already been said, get a pair of clippers and trim it down. I'm not massively hairy but I find it gets a bit untidy if I don't keep it in check. It also won't feel as weird if you shave/veet it all off.
Trim with clippers.
Also, shaving doesn't make hair 'grow back thicker' - but it may look thicker initially when regrowing because the hairs are blunt rather than tapered to a point.
Which he's quite clearly trimmed with clippers :confused:
not necessarily as I don't have crazy body hair either.
I have an almost smooth back apart from like a square patch at the small of my back.
my chest has some hair but less than him and my abs/belly hair is similar to his just a little thinner
Mine is kinda like
accept the white patches have a tiny bit of hair but you can barely see it
you'd probably think I trim if you saw me and assume I shave my back/shoulders
Leave it as is. Nothing worse than a massive red rash all over your back.
Plus, let's have it right, the birds will be loving it.
