Help me choose a NAS please
24 May 2011
West Sussex
Hi all,
Currently i have an itx WHS 2011 rig with 5 drives in a software JBOD Raid setup. Its great but it can be loud sometimes and its far too large in terms of geometric size.
I would like to get a simple home NAS where i can store my films and music and also backup vital PC files. (wont bother with steam games etc, just documents)
I am considering a 2 bay NAS with a pair of 3 or 4TB WD Red drives in a raid 1 for redundancy.
Would anybody be able to help find me an ideal NAS for my situation? Thanks.
Also worth mentioning that i am on a University network most of the year which has some interesting features. Hope fully this wont cause an issue?
Synology, whichever one fits your budget and needs. I've got the DS214se and it's great.
The DS214play is a new product line which has hardware built-in to make transcoding video files work a lot better for playback on DLNA devices such as TVs, Roku boxes etc. So if you can afford that then I'd recommend it.
So basically you are both saying that synology products are certainly worth the additional outlay and I should just choose what I can afford? Their software and support are both good as well as the hardware?
Yup. Their support is excellent. I wanted to use a networked UPS that they didn't support yet, and they remotely connected to my NAS and set it up for me.
RAID 1 is ok so long you have regular back-ups elsewhere. RAID 1 is good from a mechanical (disk failure) but provides NO protection against deleted files, virus or fire etc.
Don't worry, i know the difference between redundancy and backup :) Going to have an off site solution as well.
That's really impressive. :eek:
Yeah, they've won me as a customer for life for all situations where one of their products is a suitable fit. I didn't want to forward SSH ports so they were happy to use a VPN (and install the client), connect using a username and password I had made for them, SSH into the NAS and set up the SNMP connection based on the details I had given them. Absolutely faultless service.
