Forget the damn WATTS, look at AMPS on the single 12v rail.
You are 100% clueless and no help to the OP, so touché fool.
just thought i'd tell you
watts = amps x volts
you're telling me that the 12v rail supplies 12v
so i'll tell you that given that volts is a constant, amps and watts both increase linear fashion![]()
You done Trolling as its not helping the OP!
@ OP, sorry I cannot go on when a fool trying to be smart says I pull figures out of air (assume he means thin air) after I posted links.
He has such a boner for wattage he does not know the amps on each rail are important.
I am done.
This is really helpful indeed and i suppose its time for a psu upgrade, if you wouldn't mind going the extra mile would you help me find a suitable one so i don't make the same mistake again? I was looking at this one a few days ago: http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-EA&groupid=701&catid=123&subcat=2464
And I did tell him to lower GPU clocks if you READ.
and if you haven't already realised, the ocz zs has only one rail
@ savgebeast, That EVGA is a good PSU for price and made by SuperFlower so look at the Superflower Leadex range also.
Yes its overkill but again a good price and a very strong single 12v Rail with 83 AMPS.
You have not mentioned your CPU etc.
I take it the OP has 2 x 8 pin pci-e cables plugged in?
If the card was faulty I would expect it to have the issues every time it was under 3D load.
I'm presuming this is the PSU in question.
http://www.techpowerup.com/reviews/OCZ/ZS_750W/
If you read it, it doesn't instil confidence.
It is rated at best for a mid range system.
I would be looking at the PSU failing/not being up to the job.(IMO)
