The way the case is ment to be set up is:
3x120 or 2x140 top exhaust
3x120 or 2x140 front intake
1x140 or 1x120 side exhaut
But i currently have it set up as follow:
Top has 4 fans (push and pull on H100) 2x SP and 2x AF both set up to exhaust with the AF on top of the radiator and the SPs bottom of radiator
the side fan i took the default 140 that came with case and added corsairs 120 AF to intake instead of exhaust as i already have 4 top fans doing that
and the front 2x140 are intakes
Is this a good set up? or should i change the side to exhaust? what about my radiator set up?
Would i see any benefit of adding a fan (corsair 120AF) on top of the SSDs at the bottom of the case as intake or exhaust?
