Introducing the brand new GeForce GTX TITAN Z
OcUK Staff
12 Apr 2008
OcUK HQ
We are introducing the brand new GeForce GTX TITAN Z.
The GeForce GTX TITAN Z is a gaming monster, built to power the most extreme gaming rigs on the planet. With a massive 5760 cores, 12 GB of 7 Gbps GDDR5 memory, and the industry’s most advanced power delivery system, it’s easily the fastest graphics card NVIDIA has ever made.
GTX TITAN Z is designed with the highest-grade components to deliver the best experience—incredible speed and cool, quiet performance—all in a stunningly crafted aluminium case. Plus, it’s loaded with advanced technologies like NVIDIA ShadowPlay™ to capture and share every moment of gaming domination, ground breaking NVIDIA G-SYNC™ display technology, and NVIDIA GameStream™ to stream games to the NVIDIA SHIELD™ portable.
Click here for more information: http://www.overclockers.co.uk/LP/nvidia-titan-z.php
Asus GeForce Titan Z 12288MB GDDR5 PCI-Express Graphics Card @ £2,399.99 inc VAT
If you crave only the very best, then Titan Z is exactly that, featuring a pair of the most powerful gaming GPU's available, Titan Black Editions fused onto a single PCB. Featuring a whopping 5760 CUDA Cores and a massive 12GB of GDDR5 memory operating on a 786-Bit interface, makes this the perfect card for a 4k monitor setup.
With advanced dynamic power balancing and 12 phase power supply, not only is this card incredibly fast out the box it also sports some very impressive overclocking ability as well. Power balancing ensures both cores are locked at the same speeds always to ensure the smoothest possible FPS experience with no micro-stutter of any kind.
NVIDIA keep noise levels to a minimum by using an extra-large axial fan to keep this beast of a card as cool as possible along with dual vapor chambers and a 60% larger fin stack area.
Tested at 3840x2160, with AA and high settings on a 3960X at 3.3GHz yielded above 40fps in Batman, Crysis 3, Bioshock Infinite, Battlefield 4, Far Cry3, Metro Last Light and Tomb Raider, making this truly a 4k capable gaming graphics card.
Also being a Titan GPU it is ideal for BIOinformatics, Computational Chemistry, Computational Fluid Dynamics, Computational Structual Mechanics, Data Science, Defense, Electronic Design Automation, Computational Finance, Imaging & Computer Precision, Medical Imaging, Weather & Climate and Numerical Analytics.
Features:-
- 450W Cooling ability at 2700rpm
- 375W Power requirement (Stock Clocks)
- Maintain over 40fps in the latest games at 4k resolution
Specification:-
- Cuda Cores: 5760
- Base Clock: 705MHz
- Boost Clock: 876MHz
- Single Precision: 8.1 Teraflops
- Double Precision: 2.3 Teraflops
- Memory Config: 12GB / 768-Bit GDDR5
- Memory Speed: 7000MHz
- Power Connectors: 2x 8-Pin
- TDP: 375W
- Outputs: 2x DL-DVI, 1x HDMI, 1x DisplayPort 1.2
- Interface: PCI-Express 3.0
- Warranty: 3yr
Only £2,399.99 inc VAT.
ORDER NOW
EVGA GeForce Titan Z 12288MB GDDR5 PCI-Express Graphics Card (12G-P4-3990-KR) @ £2,399.99 inc VAT
Features:-
Specification:-
- Cuda Cores: 5760
- TDP: 375W
- Warranty: 3yr
ORDER NOW
Gainward GeForce Titan Z 12288MB GDDR5 PCI-Express Graphics Card @ £2,329.99 inc VAT
Features:-
Specification:-
- Cuda Cores: 5760
- TDP: 375W
- Warranty: 2yr
Only £2,329.99 inc VAT.
ORDER NOW
Gigabyte GeForce Titan Z 12288MB GDDR5 PCI-Express Graphics Card @ £2,399.99 inc VAT
Features:-
Specification:-
- Cuda Cores: 5760
- TDP: 375W
- Warranty: 3yr
ORDER NOW
MSI GeForce Titan Z 12288MB GDDR5 PCI-Express Graphics Card @ £2,399.99 inc VAT
Features:-
Specification:-
- Cuda Cores: 5760
- TDP: 375W
- Warranty: 3yr
ORDER NOW
OcUK GeForce Titan Z 12288MB GDDR5 PCI-Express Graphics Card @ £2,399.99 inc VAT
Features:-
Specification:-
- Cuda Cores: 5760
- TDP: 375W
- Warranty: 2yr
ORDER NOW
Absolutely outrageous card! It's expensive, but they can basically charge whatever they want, people are still going to buy them! These are not the cards of mere mortals...
Is it just me or does saying "over 40FPS at 4K" not seem that great? I know 4K is demanding, but you'd think if anything could get a solid 60, it would be this. It just seems like a strange bit of marketing...
I guess it's mainly for raw compute performance, like they say, rather than gaming.
Forgive my ignorance, but is it 6GB per GPU, or 12GB addressable by either?
That is to say if it's the former, wouldn't two Titan Blacks be a better buy?
