- 28 Mar 2005
- Newbury
What incident or attack what you choose a paper on?
OcUK Forums DDOS a few years back.
"Digital forensics", is this as cool as it sounds?
Did you get it published or have you had anything published. Would love to see your work?
consider justifying some comparison criteria at the beginning and then using a table for the actual comparison.
Hey all,
Could do with some advice and direction again - now remember i have not written at a higher level before, so from my feedback from the tutor, could you tell me what they are looking for:
1. I have to compare Wireshark to 2 other similar tools, which i have done, but the tutor has said:
Any advice?
get out of GD then
That sounds's quite simple. All he wants for you to do is create some criteria for comparing the two, for example, how many letters in each name or the size of each file (obvious bad examples) and then discuss why they're appropriate and create a nice little table showing what they all have in relation to your criteria. Like the sort of tables Microsoft use to show you what each of their Windows' versions can do in comparison to the other. Although this would most likely just be a simple cell table.
3 Papers?
Good luck with work life after uni if you think that is a lot![]()
