nvidia Driver Crashing
28 Feb 2012
London, UK
Been playing LoL for the past few days and black screens have been occuring. Didnt know what was causing it, driver or game, but its happening in other games. Eventually, watch dogs crashes and I see the driver crashing message in windows.
Been running this INNO3D DHS 780 for over a month and this issue is only just starting to happen.
No OC done myself, just factory OCs.
Does the card need an RMA?
Before you RMA it drop the clocks down to stock and try it.
Graphics display drivers tend to crash when there's an instability such as unstable clocks, but it could also be software/PC related and not the card at all.
So yeah, first off is to drop the clocks and test to see if it continues, if it doesn't then you're free to RMA since I assume the factory overclocks are guaranteed?
If you don't want to RMA then you need to start the whole, testing in another PC, thinking about what changes to hardware/software you've made recently..etc
Tried to drop to stock, but afterburner and precision show the card at +0 etc.
Should i look up the stock clocks and - the total off?
Does anyone know how to get afterburner etc. to show the actual clocks like it used to be?
Not sure what your issue is, but you could just press the "reset" button on Afterburner? :confused:
You could also download GPU-Z which will tell you what the stock clocks of the card are, and what it's current clocks are.
This is what I mean. Resetting will just set it to factory OC.
I will do a driver reinstall later i guess.
Reinstalled drivers and turned down factory OCs but still crashing. Will probably RMA.
Instead of asking how an RMA works with INNO3d, does anyone here now? Whats the turnaround time generally?
Right, thanks for that. I guess I'll need to sort out when to send it off to prepare for the worst case scenario of a 28 day wait.
