Gutted, just missed out :(
I'm even sad enough to have paid £4 for a plastic memory tray with lid.
Link me bro.
Seriously, sitting at my desk now I can see maybe 5 kits laying about, thats not including whats in storage (rammed in a box in the spare room!).
I normally ignore the dram volt limits listed but they're the sammy ones which are rated for 1.3v stock and I managed to kill one with 1.7v lol. Most likely a gammy module
1.75 on my tg kit in sig for 2600mhz, i thought that was high for ram. But from reading a few posts on here about ram clocking, it seems to be a pretty mild voltage.
24/7 1.75v would be about my limit. Benching on has well, up to 1.9v is roughly where it stops scaling on air (as I'm reliably informed by 8 pack). Though my current best psc kit doesn't scale well above around 1.8v.
I found the same with my PSC although both the chips I've benched it on had weak IMCs it topped out at 2400mhz or so with very loose timings on my 3570k and 2222mhz 7-10-8
Corsair Dominator GT 2000mhz (2x2GB) 8-9-8 PSC, by FAR the single worst memory kit I've ever used, best post was 2200mhz 9-10-9 @ 1.9v DRAM, 1.18v (SA/IOA/IOD/PCH). Terrible. 2400mhz wouldn't get a look in even at 11-12-11
IMG_5217_zps69ecbdfc.jpg~original
Got the tray, but clearly not designed for tall RAM.
Are those GT's the ones you got off MM recently??
Aye, was 2 different kits though, the other kit is a 9-10-9 2200 kit (I think) which is yet to be tested. I'm still not overly satisfied the x-oc is brilliant for memory tuning (outside of the ln2 bios) so I'll leave the other kits waiting while I put the new mb in.
Have another ripjaws kit to test to, 1600c7.
Oh, was gonna say i'll have 'em off you if you wanted to get rid and see what they would do under X79/quad, maybe not now :confused:
Still waiting on the Pi's to arrive, hopefully not long now.
Nice!! Maybe just in time for christmas :D
I'm here!!!!!!
As it is I have:
4 x 4gb hyperx 2400c11 (does 2400c9 or 2133c8)
2x4gb Trident x 2400c10 (does 2500c9)
2x4gb hyperx 1866c11 (does 2200c11)
2x2gb ripjaws 1600c6 (does 2450c7)
2x2gb dominator gt 2000c8 (untested)
2x2gb dominator gt 2200c9 (untested)
Damn that's awesome /drool :D
Wouldn't rule it out just yet mate, iirc 8 pack ran the same sticks in quad on x79. I'm just after a backup kit to my c6 ripjaws
They are by far and away my most prized possession (memory wise). Completely lucked out finding them too, some random retailer that usually only sell OEM desktops/laptops had them listed for ~£40, came with z87 plastered all over it and a manufacturing date of 2013, which is quite unheard of for psc. Hopefully get a bit more out of them on z97
What's the code on those ripjaws Paul?? I keep looking for some decent ram, want enough for quad, rarely come about now in 12gb sets so I can lose 2 of em. Some perfect storms would be nice!!
Poland from Xtreme Addict.
http://www.gskill.com/imgs/5/2220_537c7eed06940.jpg
The guy in the middle with glasses.
I think he's only just posted them to be honest..
Ahh, either way they should be epic to bench with, try the teamau psc 2400-2600 profile on your soc force and tweak on from there, found that the easiest way to get the best from good psc kits.
I'll grab the part codes for you tonight nick, comes in 2x2gb packs as apposed to the usual 3/6x2gb tri kits.
