Worthy upgrades?
25 Aug 2005
From
AMD Phenom II X4 955
MSI GeForce GTX 460 Cyclone 1GB
To
Intel i5 4670k
MSI GeForce GTX 760 2GB
Will it be much of a step up in terms gaming performance and are there any cheaper alternatives to the above as I'm guessing the GPU is more important than the CPU.
It will be a big improvement :)
A 270X would be a cheaper alternative for the graphics card.
Thanks for the reply
I should have mentioned that the hardware needs to be intel and nvidia because I'm planning to have a dual-os setup (win7 and osx) at some point
The cpu will make a big difference I some newer titles (lots of cpu bound stuff these days), and the gpu will provide some decent grunt too.
Thats a decent upgrade. I dont know exactly what you have or can do but id suggest.
Getting 'the right gear' to get a good OC on that CPU.
Look second hand for a GTX 670, they are faster than the 760's and cheaper too.
Get a GPU with a good cooler, twin fan coolers are helpful.
