Suitable card for AMD II x4 640
11 Feb 2010
England
Hey guys,
Just wanted to get you guys views on what card you could get away without bottlenecking the cpu listed in the title.
It's for a friend and not to sure of the additional specs but was a prebuilt system from ocuk so the psu should be at least half decent.
He was thinking of getting a 2nd hand 7950 but is this pushing it too far? Also open to other recommendations :D
For 2nd hand, go for a 7850 2GB. Even a 5850 would get bottlenecked, but 1GB vram is not enough for games at 1920 res thesedays, so might as well go for a 7850 2GB.
And he should really overclocked his CPU to 3.60-3.80GHz to help with reducing the bottleneck.
It's not like he can't upgrade the cpu as well. Phenom ii x4s are pretty cheap or put a fx 6300 in there if the mb will take it.
My second comp has a ph x3 @3 ghz and a r9 270 and plays games at high and ultra well at 1080p.
This.
But that CPU is pretty weak no matter what you do to it. a used Phenom II x4 is much better and will drop right into the motherboards socket, you can find them for around £50.
Something like an X4 955 or 965 would be ideal for a 7870 'ish card.
