New PC Build
16 May 2012
Hi Guys,
I am after your advise here. I am planning to upgrade my machine with new cpu, ram, motherboard, and graphics card. I am an AMD man so the processor I will use is.....
1) AMD FX 9370 4.4GHz Socket AM3+ 8MB L3 Cache Processor
So this is what I will build my machine around. I want to keep the components balanced so which of the following woiuld you buy for this processor?
2) Graphics Card.
3) RAM 8GB+.
4) Motherboard.
Please don't buy that cpu. They run very hot, and are also power hungry. You would be better off with an intel i5/i7.
As said above the 9370 is a poor choice.
Even though its the same price as the i5, you'll need to buy a VERY expensive (for AMD anyway) motherboard and Top end Cooler to maintain the '5ghz' overclock.
Take a look here at its gaming performance too: http://www.xbitlabs.com/articles/cpu/display/amd-fx-9590-9370_5.html#sect0
The i5 and i7 are superior and i think this statement (from the review) sums it up well:
So it looks like increasing the clock rate of processors with Piledriver microarchitecture can’t make them attractive as gaming solutions. The problem is rooted in the microarchitecture itself which has a relatively low efficiency in terms of performance per core.
Yup, if you haven't got a mobo just buy an intel CPU with a 115 mobo socket. This is good, as you currently don't have a mobo, so you don't need to go into the hassle of purchasing a new mobo with a socket that fits an intel, when you previously have an AMD one. So get an i5 (especially for gaming).
Also, i used to have an AMD processor, but upgraded to an i5 (best choice of lyfe). :)
Ok, so my AMD loyalty is now swayed towards Intel. So for the i5 - 4670k processor what are good motherboards for this around £100 to £160?
Recommended RAM?
And what Graphics card could go with this and not be limited by the CPU. I am not planning on massively overclocking the CPU but may do a little.
Could get an i7 and a first GPU but not sure you would really need it. Maybe add a SSD, and what PSU/Case/cooler do you have, if you have a decent heat sink just drop this one. Motherboard comes with free gaming headset too.
YOUR BASKET
1 x Powercolor Radeon R9 280X TurboDUO 3072MB GDDR5 PCI-Express Graphics Card £229.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £173.99
1 x Gigabyte Z97X-Gaming 3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £109.99
1 x Antec Kúhler H2O 1220 Series 4 High Performance Liquid CPU Cooler £81.60
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (TXD38G2400HC10QDC01) £59.99
Total : £665.16 (includes shipping : £8.00).
Leave the sides off the case isn't a great idea. It creates poor airflow. I think of a wind tunnel. Case are designed like that, bringing cool air in and blasting hot air out. Now imagine a wind tunnel with one wall missing.. Not cool.
This will affect your temps and OC ability.
I.suggest you put them on and get a better cooler.
