- 22 Feb 2014
Missus has a 1.6 W reg focus.
The alternator and battery have both been tested and are fine, (It has in fact had a new battery and had that replaced under warranty just in case)
However occasionally the battery will be completely dead and the car will need jump starting I do not know what is causing it.
She is absolutely certain that nothing is being left on
headlights were off, radio switches off when you turn the car off, interior light is set to switch off when door is closed.
Something is obviously faulty somewhere but intermittently so the garage can't diagnose it.
It happened again today but the battery was so dead I couldn't bump start it (we live on a hill) I had to get my car and jump start it and it now works fine again
the last time this happened was probably 2 months ago, it has happened twice in a week before now.
generally speaking she does do mostly short runs in it and I wonder if that is related but it has been used recently on journeys over 20 minutes which should leave plenty of charge in the battery.
any ideas as I am pulling my hair out with it ?
related or not I do not know, when getting into the car today (with battery dead) there was a ticking noise coming from the fuse box area under the glovebox whilst the door was open, when shut the noise stopped and obviously once the car was running the noise was no longer there either.
