Asus Maximus IV gene
those pins all look ok to me
you can try leaving the cmos/mb battery out for 10 minutes then try,could try the corsair cooler if its got a backplate,it might pull the board in and make the slots work
tried it still the same , so according to manual code 55 is no ram so why is everyone saying bent pins? is it not mobo faulty?
I can see a slight bent on board but nothing major.
pins look fine as said earlier code 55 useually turns out to be bent pins or the cooler to tight have you tried it out side of your case
