Gtx 770 2gb Blackscreening on Load
23 Jan 2013
So recently since watchdogs came out, my pc was blackscreening under 100% load and then restarting or black screening, fans going crazy and me having to turn it off at the wall.
I bought the forest and the same thing happened..
Decided to run kombustor and it happened on that, got a video for you?
Is this a GPU problem? had a issue similar when I got the card at xmas, turns out it was the PSU and I replaced it and it worked fine.
http://youtu.be/Z7ZAoSHUZO0
Also am I covered for warranty? cause I really do not want to fork out another £240..
~Mochan
Does it do it in any other game?
Edit. wait... it does that outside of games and in game?
You say recently, since you installed Watch Dogs, did you also install 337.88 Drivers, or through some Auto Install?
Some ppl have been having problems with those drivers. if your running them it might be worth removing then using DDU http://www.wagnardmobile.com/DDU/ and installing older drivers.
DDU how to:
Unistall the drivers as normal, before rebooting run DDU
DEY TUK ARR BLACK SCREENZ!
That's a reasonable PSU so shouldn't be playing up. However restarting when under load is sometimes a sign of a faulty PSU.
Have you got any overclocks you could return back to stock?
Okay so I changed the auto adjust temperature fan speed to when the gpu goes over to 60 degrees the fans go to 100%, pc very noisy, but it is all working? Is there anyway to add more cooling to reduce the noise and do the thermals need replaced.
I also do not have my side door on pc, does this cause it?
